Old February 19th 2011, 07:54
slushrush slushrush is offline
Porsche 915 gearbox & 217bhp Subaru Engine
Subaru EJ20 turbo engine converted to fit into a VW. Has been dyno'd at 217bhp and run a best 1/4 mile time of 11.60 in my race car. Everything is included to fit into a VW apart from the adaptor plate, included is the following:
EJ20 Turbo Engine
High pressure fuel pump and filter
Aluminium header tank
Reversed coolant manifold
Aluminium coolant pipes
Renault radiator and fan
Autometer water gauge
Charge cooler, radiator and pump
Stainless Steel exhaust system
Modified wiring loom by TSR
Also have Subaru clutch and flywheel so if you wanted to use the RJES bellhousing route you can.
£1100
1979 Porsche 915 low mileage gearbox from Pro 9 Porsche with front mount, clutch, starter motor, gearstick and gear shaft. To use this with a VW engine you need a flywheel from KEP and to modify the rear VW mount with some spacers.
The gear ratios are as follows:
3.86 R&P
3.18 1st
1.83 2nd
1.26 3rd
1.0 4th
0.82 5th
This gearing makes it very similar to having a T1 close ratio gearbox with 1st to 4th with a free way flyer gear in fifth. These gearboxes can handle 300bhp+
£1300
Would sell both together for £2200.
Old March 5th 2011, 17:18
andrimot andrimot is offline
You have pm!
True germanlookers are air cooleds!!!
Old March 11th 2011, 08:06
Originally Posted by andrimot View Post
You have pm!
I couldn't help but notice the siggy was "True germanlookers are air cooleds!!! "
Looks like a good deal for those on the European side of the Atlantic for both the 915 and the Suby.
(2004-2008): 1971 1302 w/2056
Old March 14th 2011, 16:42
Oasis
what do you mean?
Andreas
Old March 14th 2011, 19:38
petevw's Avatar
petevw petevw is offline
Andreas,
Oasis probably finds it funny that your interested in this Subaru motor, and at the same time your signature states that true germanlookers are aircooled.
I'm having a good laugh about it too.
'72 super
'65 bus
'52 split
Old March 15th 2011, 09:21
Yup, that's it. I'm easily amused and I meant no offense. Actually, I'm still amused ... oh well.
Old March 15th 2011, 10:45
petevw's Avatar
Maybe he only wants the trans and not the motor?
'72 super
'65 bus
'52 split
Old April 15th 2011, 01:38
White_Noize's Avatar
White_Noize White_Noize is offline
HI , i'd like to know is the engine still avalible , and what has been done to it in terms of being modified for a vw ? also where are you located ?
Old April 18th 2011, 05:07
Engine and gearbox sold
