UK Germanlook 1303 for sale
Type 4 engine, Porsche brakes, many top-spec custom parts
It is with regret that I have to sell this car. This is the first car I ever owned. It went through various modifications before getting a type 4 engine built by me, and a full nut and bolt rebuild a few years ago. Its based on its excellent original chassis which has only had the battery tray replaced. The body was profesionally painted by a local body shop. If your looking for a very quick, and superb handling German Look beetle, this is the one for you. Its handling is finely tuned with adjustable struts, front and rear suspension bracing, and front mounted battery, resulting in a 55/45 weight distribution. The large Porsche rims fit neatly under the stock size arches due to perfect offsets. The snug seats, race harnesses, sequential style shifter and Porsche steering wheel make it a very comfortable and engaging ride. Metalic grey 2-pack paint Shotblasted and Por15 coated modified floorpan to accept exhaust silencer forward of rear wheels Aero style fuel filler Carbon look mirrors Custom front airdam with vent for oil cooler Aluminium rear spoiler Front mounted battery Engine / Gearbox VW Type 4 2000cc 1800cc style case 2000cc crank 94mm pistons/barrels 1800cc heads race prepared by MicroGiant - 41mm x 34mm valves 1700cc rocker shafts with Ford Courier swivel foot valve adjusters Straight cut steel cam gears 34mm Schadek highflow oil pump 215mm flywheel Dual 45mm Dellorto carberettors with rampipes Porsche 911 Fan/Alternator with custom fan shroud 1/2 litre deep sump Pertronix electronic ignition module BAS exhaust header with custom silencer VW AT code 4 speed gearbox Suspension Standard 1303 IRS chassis modified to house exhaust silencer Custom adjustable struts with 90lb springs BugPack front and rear uprated anti-roll bars Custom & Speed Parts aluminium strut brace 22mm rear torsion bars with Koni gas shocks 3-piece Kafer-Cup brace Brakes and wheels Porsche 944 hubs machined to take beetle bearings on stock drum brake axles, Porsche 993 4-pot calipers and 290mm x 24mm vented and cross-drilled discs Porsche 914 rear discs with VW Mk4 Golf rear calipers with modified Golf handbrake cables Goodrich Stainless braided brake hoses all round. Stock master cylinder Porsche Cup 2 alloys 7.5"x17" ET65 and 8"x17" ET52 Interior Cobra Aqua 4x4 seats Sparco race harnesses Porsche 944 steering wheel Stock rear seat Pictures, full restoration and build blog at www.fastbug.net. Car is located in Bristol, UK. £5995
fastbug.net | FastTrack Dub Club "Straights are the boring bits that link corners together" |
Can't use links
Sorry can't view any of the pictures through the links...
'72 Type 1 - GT '69 Type 2 - Bay |
