Old April 25th 2011, 14:14
T5WOB's Avatar
T5WOB T5WOB is offline
914 box in
well all in now .lot of cutting but got there in the end .just got bug @5 speed shifter to fit and shorten gear rob to do. clutch cable fitted in ok .but the adjuster on the end of clutch cable is wound all the way down the end of cable and there still a bit of slack there .will this pull up when clutch is in .http://www.flickr.com/photos/1662095...7626576216402/any help would be good guys .thanks martin
kerb$ide ku$toms
