Old July 16th 2011, 03:29
kendy's Avatar
kendy kendy is offline
Bihalogen H7
I want to show you 'home made' lens lights
http://imageshack.us/photo/my-images...517941734.jpg/
I do all by myself - only things i bought are glass from 'clear lights' and bihalogen H7 lens (hella).
It also has ring with led 'day light' (above black lines on ring) and blinkers (under the black lines).
What do you think about it?
Best regards from GLooker from Poland
K.
Best Regards
kendy
Old July 16th 2011, 11:15
JIMP JIMP is offline
I think that you should start building mines too!! Seriously now, very cool stuff, maybe you could share some more info or photos, congratulations on these
Friendly
Dimitrios
Old July 18th 2011, 07:42
Hi Kendy,
I've not seen these in the Hella catalogue, do you have a description/part Number?
Old July 18th 2011, 13:08
Here's a UK source Clive:
http://www.s-v-c.co.uk/product/90mm-bi-halogen/
Old July 18th 2011, 19:03
Do you have a shot of it lit up? Lights on?
Old July 19th 2011, 08:22
Thanks Rich that's brilliant : (forgive the pun)
Now, if I put two pairs of these in the front of the Clan with mains and dips wired together with +100% bulbs ................... that's equivalent to 1840W of halogen power for 38amps, wow those lanes will be like daylight!
Old July 19th 2011, 09:58
kendy's Avatar
195Ł?
buahaha...i bought mine for 40E at 'polish' eBay
same like this:
http://allegro.pl/soczewki-bixenon-h...697313031.html
All stuff i made on my CNC - i have a technical documentation so im able to build few more
Only thing i need to buy is bi-halogen with 80mm lens -
Lamps are made of poliamid and painted with blackmatt. It has a 'position' light too made by me inside the len.
I will intall it in this weekend and will show you some pics 'on car'
I will also calculate costs and will inform you about.
Best Regards
kendy
Old July 23rd 2011, 06:46
Nice work Kendy! What would it take to make that set up for the older model headlights before 1967?
Old September 12th 2011, 10:50
kendy's Avatar
I have finally finished my lamps
Works fine
http://www.youtube.com/watch?v=e3eT6GTokTY
Best Regards
kendy
Old September 14th 2011, 16:09
Really nice, very good look and function!
Old September 14th 2011, 19:02
How long is that unit? It looks like it would be too long for the Beetle headlight bucket.
Old September 15th 2011, 05:00
kendy's Avatar
its a little bit longer - 5cm - i just cut hole and weld kind of thin
but now, when i finish it i know that its possible to build lamp without changing bucket - next pair of it will be for standard bucket lens will be closer to lamp glass, now its about 5 cm between len and glass
Best Regards
kendy
