Old August 16th 2011, 07:40
aircool aircool is offline
944 fuel sender
Does anyone know if an early 944/924 fuel level sender will fit in a beetle tank?
I have 944 gauges and the fuel level works(ish) until it get low on fuel and the gauge flicks wildly about
Anyone tried this option or have a work around?
Old August 16th 2011, 13:04
On a torsion beetle I've seen them fitted with spacers.
Old August 17th 2011, 04:54
Thanks for that, I will give it a go.
Old August 17th 2011, 17:21
Ricola (or anyone for that matter) do have any ideas on dimensions of the 944 sender i.e. the length? how much spacing is required?
Old August 17th 2011, 17:46
can't remember off the top of my head, but I believe a spacer about an inch or so is required. Search the wasserboxer bug on VZi, he used 944 gauges and fitted that sender
Old August 18th 2011, 15:08
owdlvr's Avatar
owdlvr owdlvr is offline
If you're really desperate to know I could pull the sender out of my 944.
It's an '83.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old August 19th 2011, 08:04
Thank you very much for the kind offer Dave, I've just ordered one from a breakers yard at a good price so no need thanks.
I figured I would take a punt at making it work.....fingers crossed
