Old November 8th 2011, 14:02
kendy's Avatar
kendy kendy is offline
Modified sway bar?
I installed Kerscher lowering struts but now i need modified sway bar becouse standard one rotates my suspension arm to back when i lower car
Can you help me, please?
http://imageshack.us/f/39/vw1302.jpg/
Best Regards
kendy
Old November 9th 2011, 09:14
Easy. Flip the anti-roll bar i.e. take it off turn it over so that the RHS fits in the LHS and vice versa.
Old November 10th 2011, 10:53
kendy's Avatar
i read on Samba that its not good solution for 3 bolts suspension only for 2 bolts
Best Regards
kendy
Old November 11th 2011, 12:33
The flipping of the AR bar allows the entry point into the TCA to be more axial with the bush. The only comment that I can think of in relation to the 3 bolt strut is that it doesn't need the tie rods flipping because they hit the AR bar when lowered that only applies to the 2 bolt. Looking at your installation I would certainly try it.
