Old February 10th 2012, 20:19
Mr Big Mr Big is offline
Max disc width on Boxster non-S Calipers?
Hi guys, I've been away for a long time but I finally have some time to get on with the bug.
I've come up with this crazy idea of using some Ronal wheels which are 5 x 108pcd. In order to do this and still be able to use off-the-shelf discs I have made up some custom hubs. At the moment I have 944 turbo front 4 pot Brembos and 964 (911) C2 2 pot rears to go on the back.
They don't really match up as a set and a friend has offered me some monoblocks from an early non-S boxster. The problem is I don't know what the maximum disc width I can use with these calipers is. Can anyone help so that I can figure out if I can get some discs that will work.
The entire ethos of this conversion is that once it's finished I will be able to just swap discs and pads straight from the shop at the track without having any machining etc needed.
Cheers
1969 German Looker in progress:
1776 turbo EFI motor (eventually!)
Built IRS Box
944 Turbo Brembos (Fr)
964 C2 Brembos (Rr)
Old February 11th 2012, 00:20
flat flat is offline
Boxster front rotors are 299x24.
I just added this to my site with lots of info:
http://vdubengineering.com/technical...e-conversions/
Cheers,
www.vdubengineering.com
Old February 12th 2012, 20:22
Thanks Lanner, much appreciated.
Awesome site too
Built IRS Box
964 C2 Brembos (Rr)
