Old February 14th 2012, 14:16
johan johan is offline
1303 sti project 325hp+ on the road!!
hello
i'm johan and from holland and read a lot on this forum
i also have a project off my own i'm now busy with it for 2 year
i have a 1303 from 1972 and have done some mods
but i started with this
front and rear porsche 944 trailing arms
944 disc's and boxter calipers
rear mod to unibail coil overs
porsche G50.03 964 transmission
KEP connection kit a clutch kit
subaru ej207 sti engine 2002 runned 36000miles
custom intercooler inlets
custom wheels 16"steel rims widend front 2,5cm
rear 6,5cm
and much more
also have a full rollcage and doorbars (removaible)
did al the engine wiring (big job)
custom 3"exhaust magnaflow mufflers
custom inlets on the front wing hope it will work to let the airflow out off under wings at high speed
intercooler inlets placed the rear windows 15cm inside and airflow is getting out to the original air outlet under the rear window
i'm now busy to get the body ready for paint
but it is getting slowly i'm also renovating the house
this is how the engine look like now
custom little wing to improve air flow to intercooler
but i hope i can drive i the second half of this year
i have also some video's on youtube
from the first start
www.youtube.com/watch?v=fae2gHi20fE
first drive
www.youtube.com/watch?v=L1PKfK_BaWE
Old February 14th 2012, 15:55
Xellex's Avatar
Xellex Xellex is offline
Cool project, I think I have read about it before. I don't remember where. I'm currently searching for some 5x130 steel rims to use with winter tires, and remembered exactly your project, where you said you used some van wheels. Are these fiat ducato/peugeot boxer/citroen jumper rims? They look pretty nice on the bug..
www.vw1303s.com
Old February 14th 2012, 16:21
yes that's right the steel rims are on those types
i have them from a opel movano
need the maxi type off the van's
here's a link
http://www.steekmaat.nl/omgekeerd.ph...x130&naaf=78.1
Old February 14th 2012, 21:45
Eurotrs's Avatar
Eurotrs Eurotrs is offline
looking good, how far forward did you have to move the transmission?
Old February 14th 2012, 22:32
Welcome to the GL forums Johan. Lots of nice work going on with your 1303. Keep up the good work!
Old February 15th 2012, 14:54
Good to see you here
Old February 15th 2012, 17:55
thanks
thanks for the comments also you rich!
Old February 15th 2012, 18:01
Really cool, glad to see your definately not taking the normal route! Keep us posted, looking forward to progress shots.
Old February 16th 2012, 18:08
i placed the transmission from original 4,5cm back but if i have to do it again i will to at least 5,5cm just to have more space
it fit's under the bonnet but not more then that
Old October 26th 2013, 17:47
1303 sti 325hp+
long time ago
but i thought showing how it is looking now
intercooler intake both windows are moved 15cm about 6 inch inside in the rear
outlet is under the little wing on the back
youtube:
http://youtu.be/-2wilTC5Cs0
http://youtu.be/GrFrrbbncL0
http://youtu.be/fae2gHi20fE
http://youtu.be/L1PKfK_BaWE
car spec:
VW 1303 beetle 1972
engine
2002 subaru wrx sti (bugeye model) ej207 sti engine VF35 turbo
engine is stock
ecu: 2002 sti jdm ecu (i used jdm ecu because no need of immoblizer and keys instead of euro models)
ecu is ecutek remapped to 98 oct fuel and runs around 1,5 bar boost
should have at least 325hp+. it is not been on the dyno yet
rev.limit 7800rpm
i can get 120klm (75mph) in second gear
exhaust:
custom made 3" stainless steel with 2 magnaflow 4" mufflers
i'm driving with DB-killers it is now 2 times 2,25"
but it has no influence on the power or spool up of the turbo
but driving without db killers makes it like a rally car sound
there is a youtube link above
gearbox:
porsche 911(964) G50.03 5 speed gearbox incl shifter
that is modified to custom shifting linkage
clutch adapter kit
KEP: adapter kit
sachs stock 911 pressure plate
and high performance 6 puck kep clutch plate
spec can hold up to +/- 850nm
suspension
front: fk-coil overs
944 hubs and brake discs
porsche boxster brembo calipers
custom made steering arms/rods
custom made stabilizer bars(cupstrebe
rear: 944 suspension arms and brake discs
custom made stabilizer bars(cupstrebe)
red9design uniball system
spax coil overs
wheels/rims: steel rims 16inch rear245/45/16 front215/35/16
pre 65 chrome covers
fenders front fully steel: front widened 2,5cm 1 inch
rear widened 6,5cm 2,5inch
fully roll cage incl doorbars
2 gt3 racing seats
4 point belts
omp steering wheel
2002 sti instrument cluster
boost, oil pressure and oil temp gauges.
and much more
i have to do some little things on the interior
and polish the paint
and i need to make a front splitter
because when doing around 200klm (125mph)
it is getting to search on the road a i need to do little
steering corrections just like in old porsche's
i going to make a splitter in the front to improve this
when it is doing better and i can test it on the autobahn next year
(i'm from holland and live 15klm from the autobahn ;D )
hope you like it
Old October 29th 2013, 08:44
krukab krukab is offline
WauW !!!
No useless sh*t on my roofrack !!
Old November 2nd 2013, 03:28
graham's Avatar
graham graham is offline
1303 sti project
Nice project with some smart mods
I thought of the rear window air intake but I had already had the car painted,I think that is a very smart.Ive seen your car on youtube keep us posted with the videos.
gee dub
Old April 8th 2014, 06:41
New video with new camera
Made a new vid
Wiht a hd cam
But when i was home again it was on 720p and not on full hd
But still nice to see i think
Next will be on full hd
http://youtu.be/ldYdgGaC22M
It is al most fully done
I bought a kamei spoiler that will be fitted and i have to do an splitter
And then it is 100% ready
Old April 13th 2014, 10:40
got new video sprint 0 -200klm
wheelspin in 1 gear and to early to 2 gear but still pretty fast!!
but only the audio is still problem that i need to fix
sorry about that
http://youtu.be/PG10E8_utiI
reaction video of a mate
http://youtu.be/ri5BRdfaQ1s
Old April 16th 2014, 15:31
Installed a kamei spoiler and made a splitter underneath
For more stable drive at higher speed
Around 180 the car is getting light in the front
When i get enough downforce
I will do a autobahn run soon
