Old April 8th 2012, 11:11
essjayarr essjayarr is offline
Wheel Spacers/Stock Bearings
I'm looking for input from experience with wheel spacers on the rear of IRS cars with stock stub axles and bearings.
I bought my car with 3 1/2" widened fenders. I'm using 16x7 wheels with 37mm et.
I'm considering going too as much as 18mm spacers too fill out the wide fenders.
I've got to decide to use spacers with theses fenders or go to 2 1/4" rear fenders.
The question is, "Will the stock bearings hold up with periodic re-packing?"
Old April 8th 2012, 17:29
Mr Big Mr Big is offline
Depends how you define "hold up". If you use decent quantity bearings and grease they will work but they will have a shorter lifespan. You're not using huge wheels and they don't have a massive offset, so I can't see it being a problem.
1969 German Looker in progress:
1776 turbo EFI motor (eventually!)
Built IRS Box
944 Turbo Brembos (Fr)
964 C2 Brembos (Rr)
