Old May 25th 2012, 22:20
onixbonilla's Avatar
onixbonilla onixbonilla is offline
Oil pressure
Hi everyone.
We had just assambled a new Gene Berg 2213 engine kit I bought around 1995. All measurements were on expected values. CR is set at 8.6:1. Exhaust is 1 5/8 and carburetors are NOS Dellorto 48 tri jets.
Type 4 oil cooler.
After break in these are the oil pressure values we are getting:
40psi at idle 1000rpm cold
6 psi at idle 1000rpm after 30minutes of running
22psi at 3000rpm operating temperature
At present time have no oil temp gauge
Had read that VW aircooled are low oil pressure but are these values normal? Bentley states min 28psi at 2,500 for SAE30 at 158 F
Oil is Castrol GTX 10w40. As our ambient temperature is always around 90F should I go to oil 40 monograde?
Thanks in advance.
Old May 25th 2012, 22:35
effvee effvee is offline
Oil Pressure
Hi, sorry I don't have any answers on the oil pressure, but 6 psi just barely keeps the low oil light out. Do you have a remote oil cooler along with your type IV cooler?
I don't know how good the oil temperture will be, but I hoping that the bushed pressure relief bores will keep pressure as set.
Old May 25th 2012, 22:55
Thanks for the response. No remote oil cooler but it is full flow 30mm Berg pump and Berg relief cover and System One oil filter.
