Old June 12th 2012, 14:14
dc2-dave dc2-dave is offline
Talking New to type iv questions ?
Hi Ive just put a GB code type iv 2056cc in my 1303s & its mint .
Its running DTM V2 cooling with a Mocal 19row oil cooler .
Ive got an oil temp sender plumbed into the oilcooler lines ,but on a brief 10 mins run it hasnt moved ?
I have no cooling on the remote oilcooler currently (will I need any ? I have a 12v fan to fit if needed)
Its also running a 30mm melling oil pump (I think ) if that will make any difference ?
Just trying to sort the bits & bobs out before I go for a proper blast
Old June 12th 2012, 18:29
Could you move the sender to the oil tube filler hole, I assume that you would have a blank off there.
Do you have an oil stat fitted? 10 minutes is not much running time.
Old June 13th 2012, 02:08
Hi theres no stat fitted at the moment as
I'm waiting for it to arrive.
On the dtm the alternator stand is the
oil filler same as t1 so no where to fit the sender.
Problem is this engine has caused me no
end of problems in the past when it was in
my 914, now ive got it running in the bug ive
become attached to it & i dont want to cook it
on the 1st trip out
Old June 13th 2012, 15:41
You need to make sure the oil temp sender has a good ground on the case threads or it will never work. You could use a 914 taco plate with the sender mount in it. or weld a nut to the flat style plate and drill it.
Old June 13th 2012, 18:50
I meant the stock Type 4 filler hole on the right hand side crankcase 1/2.
Old June 14th 2012, 03:25
judgie's Avatar
judgie judgie is offline
were you have the sender will be fine, just make sure it has a earth or it wont work. 10 minutes should see a slight increase in temps if your driving it ,depends were your guage starts reading from. my autometer guage starts at 140*f.
Old June 19th 2012, 13:47
Finally got my charging issue sorted ,earthed the sender and went for a test.
Was out about 15mins before another oil leak popped up
Gauge read about 95 degrees C on run but only did about 5-6 mile.
Other than the mocal cooler on the boot floor there isnt any oil cooling , will it need a fan guys ?
Old June 19th 2012, 14:50
Oil coolers work by exchanging heat from passing air through the cooler.
No air -> no cooling. And yes, you need an oil cooler. Guess what even a stock engine has..;-)
Either mount cooler in the nose or use a fan. Its that simple imo.
Old June 25th 2012, 10:33
Sorted the oil pump leak & front crank seal leak
Fitted electric fan on oil cooler so just sorting the little jobs out now
