Old December 16th 2012, 20:52
effvee effvee is offline
Solex 34 ICT
Hi everyone, I have a problem. I have been helping a friend rebuild is type one engine. it's a type one 1835, he does not have the money for the exhaust or dual carburation now. It has a Engle 110 cam and ported stock head 40X35.5. My problem is, I can't get the ICT 34 to maintan an idle. Is there a way to re-jet this single mounted stock carb? This car should run, even with 34 ICT carb. Your imput please, anyone know a jeting that I can enlarge to?
Old December 17th 2012, 05:16
yes they can be re-jetted. The jets are inside the bowls. Are the throttle shaft bushings worn. Most of the ICT's that have been run for a long time will have worn shaft bushings and suck air making it hard to gat a good idle.
Old December 17th 2012, 08:26
Jetting sizes
Hi, I need some place to start, I think I went to 130 size, still did'nt help. I'll check the shafts, thanks
