Old March 2nd 2013, 23:32
SuperRSi's Avatar
SuperRSi SuperRSi is offline
996TT Wheels on Super with Kerscher Fenders?
I am looking to run a set of 996TT 18 inch stock wheels and tires (8 with 50 offset, 11 with 45 offset) on late aluminum arms on a 79 Super. Anybody doing that who can tell me what size fenders to order?
Old March 3rd 2013, 08:57
Late alu arms ( widest combo ) with 11cm inner and outer widen fenders from Kerscher with 11x18 et 45 996 tt, one side 10mm spacer, the other 43mm spacer. Had an accident B4 on the side with more spacer. Front with 22mm spacers with 9x18 et 50 996 tt wheels with 6mm fenders. The car looks fat but nice like a wide body 911 from the rear! Front a little too wide, I would go 4cm with 8x18.
993 c2 brakes all round.
T4 2666 1303s
Old March 3rd 2013, 09:08
-Alex- -Alex- is offline
If nobody knows, try calculator, like i did.
http://www.germanlook.net/forums/showthread.php?t=11270
Stock wheels vs 9,5" wheels
Empi 8-spoke vs 9,5" wheels.
Old March 3rd 2013, 09:18
Kerscher has stock, 2cm, 4cm, 6cm, 7cm and 11cm for the rear.
Stock, 2cm, 4cm and 6cm for stock look, 4,7 and 11cm are flared fenders.
Front, 2, 4 and 6cm
T4 2666 1303s
Old March 4th 2013, 00:35
SuperRSi's Avatar
[QUOTE=-Alex-;85676]If nobody knows, try calculator, like i did.
That does not tell me anything other than how much wider the wheels are than the stock ones I haven't seen in 10 years, which a tape measure works well on. I do not have fenders anymore and will just wait until I bolt on the rear arms and wheels later this summer...
Old March 14th 2013, 12:02
On my topic, there is everything to calculate and get the idea in theory
Simple mathematics only.
Stock wheel is 4,5" et34 and the usual empi 8-spoke is 5,5" et30, which fits well with stock fenders.
I dont know how much late 944 arms widen the rear, but this can be found somewhere here at germanlook. I think they widen 74mm total=37mm per side;
http://www.germanlook.net/forums/showthread.php?t=1993
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
This is calculated with stock arms, you must add difference between with stock and late 944 arm width and possibly a spacer width.
Adding 37mm it gives these results:
I would also put 30-40mm thick spacer. No doubt the 11cm is best option to rear.
Old March 20th 2013, 02:53
Joel's Avatar
Joel Joel is offline
79 is 2 bolt suspension, all 2 bolt supers are et41
et34 was standards and the early 3 bolt supers.
Old May 27th 2013, 17:03
SuperRSi's Avatar
Anyone here actually own and have installed Kerscher rear fenders? Because if you do a tape measure can do ALL the math I really need...
