Old May 27th 2013, 23:35
brent brent is offline
German made main crank bearings
Are genuine type 1 german made Mahle enigine bearings still avaiable? I am after std inner and 20 thou or .5mm OD if someone can help. Regards Brent
Old May 28th 2013, 01:30
JIMP JIMP is offline
so you mean std on the crank and 0,5mm on the case sise? Please verify and I'll see what I can find
Friendly
Dimitrios
Old May 28th 2013, 04:46
Yes that is correct, its brand new crank. KS would be great or genuine german mahle.
Old May 28th 2013, 05:10
They are no longer made.If you´re lucky you may find someone who has some originals in stock.Glyco is a good alternative though.
Old May 28th 2013, 08:15
Hello Brent
I can deliver KS -sorry no mahle- in the dimension you need, I'll pm you details
Friendly
Dimitrios
Old May 28th 2013, 18:31
Ok, can you please verify that they are actualy geniune "german" ones and not brazillian? They are going in a high rpm, arpm cased race engine. I need highest quality. Whats you thoughts on Glyco as an option? Regards Brent
Old May 29th 2013, 02:50
O.K. I will check this out, the glycos appear also a very good choice, we run them on our drag car with no problems although there is a slight diffrenece in the tolarances between them and the others, if I'm not mistaking they gave in general more tolerance than the others which was more favorable for our application, but problem is you have to have all the bearings available to decide which one to use, we had mahle, ks and glyco and the glyco was the one with the biggest tolerance so we decided to go with this but probably this is a unique case, maybe this is not a rule for the glycos I couldn' tell
Friendly
Dimitrios
Old May 29th 2013, 03:03
Hi Dimitrios, One would asume they will be steel back as well? Cheers Brent
Old May 29th 2013, 04:32
Yes,the Glycos are steel backed.Dimtirios is right about the tolerances,however, cases also have tolerances,especially if the case is a used case.
Old May 29th 2013, 07:51
ok thank you, yes i can see he is experianced and i am taking on board all his responce. Regards Brent
Old May 29th 2013, 09:19
Hello Brent
I asked my guy and the package is seen as made in Germany, so I suppose are the right ones, cheers
Friendly
Dimitrios
Old May 29th 2013, 20:07
Ok thats great, seems we have a deal there.....
I am also after some quaility cam bearings, would you have some genuine german made std cam bearings as well? Regards Brent
Old May 29th 2013, 20:08
My engine builder has asked for double thrust cam bearings... Ta Brent
Old May 31st 2013, 11:24
I will never use anything else other than double thrust cam bearings.Jake Raby sells them and they are made of steel.Excellent quality.You can order them with DLC coating also.
Old May 31st 2013, 17:30
I will check them out, however i feel lucky to have found some genuine german KS ones
