Old January 10th 2003, 11:22
blue4400 blue4400 is offline
What do I need?
If I have 930 TURBO OR 944 TURBO front and rear calipers what else do I need to put them on my 1970 IRS beetle? Can I even use them? I am currently using a stock drum brake set-up in the rear and CB performance 2inch lowered spindals and disc brakes in the front.
HELP PLEASE
Old January 10th 2003, 17:19
Jim Andritsakos's Avatar
Hello!
Well, you need the following :
Front :
Front rotors and hubs (needs modifications to fit)
Front rotors it must be from a 951 (298x28) to work with the 951 calipers (also 930 work here).
Rear :
Rear rotors , hubs and caliper brackets from a 944 NA (with steel trailing arms) 951 rear rotors (299x24) also here 930 caliper works but need to be modified - see Sandeep articles)
Rgds,
Jim Andritsakos
74 1303 GL (project)
89 T3 Syncro panel
Old January 10th 2003, 18:08
Post
The articles are on the main page @ www.germanlook.com
