Old September 6th 2014, 00:07
rioprelude rioprelude is offline
My 66 chop top build
Hi everyone. I've had a 66 beetle with a chopped top for the last 10 years, and recently started working on it again. Here is a summary of the build:
Purchased a rolling shell on ebay:
Stripped it down and worked on the body:
New IRS chassis with a Porsche 901:
Body shop finished and painted:
2165cc Type 4 w/ DTM shroud:
944 Turbo Brakes w/parts from Vdub Engineering + Boxster wheels:
New Beetle Turbo S. front/rear seats:
Old September 6th 2014, 00:14
Front Seats:
Headliner install (Dakota Digital gauges visible):
Fast forward to 2013, and I decided that I really wanted normal door handles (no door poppers), so I ended up replacing the door skins:
I also decided that I wanted a real glass rear window, so I cut out the chopped square rear window section, and cut down an oval rear clip to fit. Final install still needed, got distracted by other things:
Old September 6th 2014, 00:21
Most recently, I decided to install the new front/rear suspension from Mendeola, and the matching Wilwood brake kits:
New IRS chassis:
New Pans + Initial install:
Brake kits:
Rear Installed:
Front Installed:
Rolling Chassis. Excuse the poor alignment. I wanted to see it on the ground, and plan to powder coat or epoxy paint the chassis again, so it's not the final assembly.
Body back on:
Old September 6th 2014, 00:28
Purchased a 2.7L (78x105) Type 4 engine from GetBackOnTrack (http://gbot.dk), with Duetz cylinders, Webcam 86c, AMC heads 46x38, and a horizontal 911 cooling system:
Rebuilt Dellorto DRLA 48 carbs from Blackline Racing:
Storing it in the crate for now, until I get the car ready for it. I sold the 901 transmission, and currently have a Bus 002, with a Berg intermediate housing, and mounts. Not 100% on the transmission choice yet..
Old September 6th 2014, 00:50
Previously purchased Creative Car Craft 2.5" wider front fenders, 3" wider Super Beetle rear fenders (for the tail lights), matching running boards, and a front hood. Initial install, with two bolts each:
Looks like I almost have too much room now, with the narrow track of the Mendeola components. I guess I could lower it further, increase the tire size, or look at taller/wider porsche wheels...
The red fender in the picture, is a rusty 63 convertible shell that I picked up today. It was super cheap, but needs a pretty good amount of metal work and parts. Probably another 10 year project, but who knows, maybe I can keep it stock this time.
That's it for now..
Old September 22nd 2014, 08:38
Nice work, not likely it will stay stock!
Old September 23rd 2014, 05:09
Nice purchase on the engine! That much high tech almost screams EFI...
I would go smaller on the fenders, not bigger (=heavier) on the wheels. Seems counterproductive wrt the nice suspension components otherwise.
You have a subtle chop, subtle (stock looking) fenders would suit that well imo.
Old September 24th 2014, 09:11
Birdman69 Birdman69 is offline
That's a very nice car mate!
You got lucky with a very good looking chop.
Old September 26th 2014, 10:57
Thanks Birdman.
Agree with you Wally, but also like the wider fenders, so I thought about similar wheels with more positive offset (?) to reduce the gap between the fender/wheel. If they don't exist, I'll just get smaller fenders as you suggested.
I'm not sure about EFI yet, due to the added cost/complexity, but will run two fuel lines in the tunnel, so that I can convert in the future.
Old April 10th 2015, 14:56
Minor update. In the process of selling my 002 Bus transmission setup, and purchased a low mileage Porsche G50/01 and a 915 front mount:
My type 4 engine has a 215mm 914 flywheel/clutch, but it appears to be too deep for the G50 at first glance.
Next steps are to see if KEP offers a complete flywheel/clutch solution, or if I need to follow Walley's lead. Also looking for the factory G50 workshop manuals, so that I tear it down to get the bell housing shortened.
Old April 10th 2015, 18:31
Nice trans!
Old April 11th 2015, 03:26
I just replied your PM Rioprelude (are you Alexander?), I don;t have a copy (anymore), but could Ricola not help as he had one he wrote in my topic?
iirc I disassembled it without manual ;-)
The 215mm 914 combo will not ever work as you need a clutch plate with G50/Mendeola spline. KEP makes 228mm (=9") Mendeola clutch you can use, but you need to swith flywheels then (as I did).
IIRC, no 215mm clutch plates (not even from Kennedy) are being made with G50/Mendy spline...
Old April 12th 2015, 01:17
Ricola had the Bentley manual, but it only covers the 915 transmission. He is looking for the factory manual that covers the G50. I can probaby find it on pelican parts, but good to know you didn't need it.
I did find a 215mm g50 spline clutch but it was a 4/6 puck that wouldn't work on the street, so I will look into the 228mm setup. I was hoping to avoid machining the starter area if possible. Was this required due to the vw flywheel/vw ring gear depth being too short? Didn't know if a hybrid or porsche flywheel would solve that issue.
Thanks!
Jarrod
Old July 1st 2015, 20:46
Minor update: Ordered a custom type 4 flywheel from KEP that accepts a G50 pressure plate and ring gear. Added a KEP 930 clutch and pressure plate to fit the shortened bell housing.
Old July 1st 2015, 22:04
That's very nice!!!!
