Old November 16th 2014, 08:06
dub_crazee's Avatar
6 pots on the front of my bay
So I've started a new project, my '71 bay.
Although not strictly GL it will have GL influences.
On the front I was considering using late 944 front hubs that run outboard discs, 996 Turbo front discs (330x32) and a cayenne 6 pot calliper.
I am having trouble sourcing the front hubs-does anyone know if that hub came on other porsche models?
On the back I was going to get rid of the bay IRS and run narrow aluminium 944 rear end with boxster s discs and calipers or boxster s discs and non s front calipers. Rear end is pretty simple as I've got this on my bug.
Deano
Classic Car Revivals
www.classiccarrevivals.com
Old November 16th 2014, 10:11
dub_crazee's Avatar
I should mention it will be on a king and linkpin front end
Old December 3rd 2014, 15:41
dub_crazee's Avatar
Some Progress Just need to get the caliper brackets laser cut out of 10mm steel
Uniball coming along. Had the connecting bolt made LH/RH thread so its easy to adjust to toe in/out
Old December 30th 2014, 15:32
Bug@5speed(US)'s Avatar
Dub,
What steel did you have the turnbuckles made out of. They look like a nice piece.
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old January 11th 2015, 07:42
dub_crazee's Avatar
Hi,
They are singularly the most expensive item of all the components that make up the kit!! I cant remember exactly what grading they are i will have to check for you
