Old April 15th 2017, 15:00
Clatter Clatter is offline
944 Axle Length - Early Auto Short
Hi,
I am in the process of narrowing the rear of my car (IRS) 1"
It will (obviously) need shorter axles.
Type 3 Square/Fast/Notch left-hand (short side) auto axles are shorter by about an inch.
Makes them a good option for narrowed rear ends..
Because I am running Bus/Thing/944 CVs,
Type 3 left axles won't work, due to the splines being different.
Has anyone out there used the early/steel-arm 944 auto short axles for this?
I noticed last time I was in the yard, that auto 944s have two different length axles..
For reference:
Type 3 auto short left side axle -- 15 5/16"
944 manual axles -- 26 1/4"
Bus auto short left side axle -- 18"
Bus auto long right side axle -- 19 7/8"
Late (1986) narrow aluminum arm auto short left side axle -- 20 1/8"
These numbers are just rough - made with a tape measure.
Obviously, I have every axle except what I need..
Anybody out there that can measure their early steel-arm 944 auto short left side axle for me?
Or know where to find details?
Please and thanks!
Old April 15th 2017, 22:50
flat flat is offline
No idea on the 944 auto axles, but the splines should be same for the early 944/thing joints and type 1/3 axles. Its only the late 944s that had different splines.
The joint width is different betweem t1 and 944, but what I've done in the past is machine the t1/3 axle a touch on the shoulder to make the wider 944 joint fit. Or leave off the bellville washer and clip of you dont want to machine.
Just some options...
www.vdubengineering.com
