Old January 13th 2003, 09:58
zydeco zydeco is offline
1302/03 Disc Spindles - Part No?
Does anyone have the part numbers for the Disc brake spindles for Superbeetles (1302 and 1303)?
Thanks.
Brian
73 Superbeetle
Old January 13th 2003, 20:04
lightning bug's Avatar
I believe any 02/03 spindles will accept a disc or a drum. I'm not sure of PN's though.
Julian
'74 Super
Old January 14th 2003, 07:07
The 1302 part number has been deleted from my parts CD but the 1303 uses part number 135 407 311 (left) & 135 407 312 (right) Both cars use diffrent stubs for disc or drum brakes.
Steve C
Old January 14th 2003, 09:04
Thanks a bunch Steve!
Maybe the 1302 spindles have the Part No. stamped on them? I'll have to see when I get a hold of a set.
Thanks fellow GLers
Brian
73 Superbeetle
Old January 14th 2003, 20:32
Steve C
Do you mean you can't use discs on stock '03 U.S. spindles?
Julian
'74 Super
Old January 15th 2003, 06:33
Sorry I didnt explain that very well. The stub axles are different in the way that the disc brake stub axle has ears for the callipers and the drum stubs have mounting points for the drum backing plate. But physically you can fit a drum on disc stub and v4v. If you have a drum stub axle you could fit a disc to it and use an adaptor to bolt the calliper onto your stub axle.
Steve C
Old January 16th 2003, 01:32
Superman
1302 part numbers:
113 407 311F (left) & 113 407 312F (right)
Old January 16th 2003, 08:44
Thanks Supe!
I was just getting ready to post a message over on SBO! Good timing.
Brian
Brian
73 Superbeetle
