Old January 13th 2003, 17:53
robphelan robphelan is offline
Question Stroker Engine?
Can someone explain what a 'stroker engine' is and how does it differ from a regular Type I-IV engine?
Old January 13th 2003, 18:19
The tern stroker engine refers to an engine that has its stroke enlarged thru the use of a larger crankshaft.
Most engine builders enlarge the bore (pistons & cylinders) only & dont use a stroker (crankshaft) in the engine.
Most common non-stroker engine combos:
Type 1
1641 87 bore x 69 stroke
1679 88 bore x 69 stroke
1776 90.5 bore x 69 stroke
1914 94 bore x 69 stroke
Type 4
2056 96 bore x 71 stroke
2366 103 bore x 71 stroke
Thanks, I fixed it
Old January 13th 2003, 19:48
lightning bug's Avatar
Type 1
1641 69 bore x 87 stroke
1679 69 bore x 88 stroke
1776 69 bore x 90.5 stroke
1914 69 bore x 94 stroke
Type 4
2056 71 bore x 96 stroke
2366 71 bore x 103 stroke
You have your Bore & Stroke #'s reversed. I know you meant it the other way. 69 is the common stroke. The other #'s are the bore.
Julian
'74 Super
