Old June 16th 2020, 03:41
2 body questions
Hi lads,
Sometimes I have some physical time to spend it on the bug...
Most times I am thinking what to do and which way to go with it.
So I was thinking about 2 things for the body.
1. If I decide not to use heat exchangers in the exhaust, the holes (where the hot air goes through) in the body can be closed. How did you guys do that? Weld them shut of made a bolt on cover plate for it?
2. Do the reinforced heater channel rails from a convertible helpstiffen things up? Are they bolt on or weld on?
https://www.csp-shop.com/en/body/rei...1d-30318a.html
Old June 16th 2020, 18:40
412STi's Avatar
412STi 412STi is offline
Hello wouter
They have to be welded. Screwing doesn't make sense because it doesn't bring stability in the long run. If you want to do this, you should also weld the reinforcement plates on the A and B pillars.
To your other question:
Build 2 lids and screw them with a suitable gasket.
Greetings Gerold
STi powered Typ4 in the works...
R.I.P. 1302/'72
Old June 17th 2020, 02:46
Clear answers.
Time to design and let the lids lasercut in stainless steel
Old June 17th 2020, 15:17
Blizzard's Avatar
Blizzard Blizzard is offline
It has been done before to weld the reinforced heater channel rails from a convertible under a sedan.
But you already want to delete the heaterboxes, why don't you put the reinforcement inside and replace the heater channel with some kind of rollcage tube or a square bar.
No bulky heavy low dragging square bar onder your running boards.
Old June 18th 2020, 02:26
That's what i thought. The reason not to open up the heater channels is because they are quite solid as a rock... I only had to fis some minor holes. But that was what was visible with the body still on the chassis....
Old June 19th 2020, 19:03
Hi I did a few things on my 1303 to stiffen the body. a&b pillar stiffening and top of the b pillar and a stronger cross brace to replace the flimsy rear seat base
Old June 22nd 2020, 02:15
Does the rear seat still fit? I think I get angry faces if the kids can't ride in the back
Those convert braces are on the list, just as many other things...
Old June 22nd 2020, 03:26
I'm sure that you could get the rear seat base to fit, if the 25x50 was far enough forward for the seat base to snug in behind it
Old June 23rd 2020, 11:13
H2OSB H2OSB is offline
There was a company here in CA that sold bolt on vert rails which I wanted something fierce, but waited to long. The guy worked out of the Eyeball Engineering shop, and when the owner of EE died, the vert rail dude closed up shop and won't make them anymore. Not sure why. A buddy of mine who DID get them in time is considering making a pattern off of his.
H2OSB
johnL (aka H2OSB)
Old June 23rd 2020, 13:21
owdlvr's Avatar
owdlvr owdlvr is offline
H2OSB
This is interesting...I might be in for a set or two if he were. Can you get some photos?
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old June 23rd 2020, 13:33
I just talked to my friend who has them today. He's an engineer. He's going to make scale drawings of them, as his autocross car is currently down for an engine build. I will take them to my fabricator buddy to have a set built. I will ask if they're willing to make a jig and produce them to sell. If they're not, I'll do what I can to get a copy of the drawings/pics to you.
johnL (aka H2OSB)
Old June 23rd 2020, 13:54
owdlvr's Avatar
You rock!
Old June 24th 2020, 04:46
Cool, a copy of the drawings would be nice!
It is just one of the things I would consider, but maybe it is overkill to do so (because standard AB engine).
In the future I am planning to build a bigger motor with the stuff I have lying around (engle w110, 2 36mm IDF webers) but I do not know the displacement yet. So reinforcing the body might be overkill?
The holes for the heating, I might use them to run the wiring loom through to the engine in stead of the standard through the C pillar.
