Old October 16th 2020, 05:58
Hoghead Hoghead is offline
915 clutch cable
I have given up on a hydraulic clutch, and now decided to use a cable clutch for simplicity on my 915 gearbox project. All the 915 parts are in hand but for a cable
Is there an off the shelf cable that can be used in a Type 1, or am I going to have to make my own cable?
Old October 16th 2020, 12:07
DORIGTT's Avatar
DORIGTT DORIGTT is offline
What made you turn away from the hydraulic setup?
Old October 18th 2020, 22:31
I am RHD, so no room between the brake MC and hump for the clutch master.
I could dream up some other mounting for the MC, but at this point a cable seems so much easier as I have the 915 parts
What to use for a cable?
I have a hydraulic crimper and machine work is cheap here in Thailand.
Old October 19th 2020, 18:55
I moved my master cylinder over and fitted the clutch master next to it
