Old January 16th 2003, 11:19
Evill Ed Evill Ed is offline
Type 4 Dry Sump Pump
Looking for info on Type 4 dry sump oil pumps. Looking for a pump that can be used with the stock cooling fan set up on a 914. I can modify the fan housing if necessary. I have seen a unit similar in design to the Remmele pump on the engine picture page that fits with the stock fan housing, but I have heard that that particular design leaked.
Looking for info on Remmele's stuff or Oliver Knuff if he has one.
Can a type 1 style, like CB performance has be used?
Any links or info are greatly appreciated.
Ed
Old January 16th 2003, 17:44
BOBTAIL BOBTAIL is offline
Hi Ed I've seen a stick shift T1 pump used where the smaller gears were replaced with some stock sized ones, and a bigger outer case ..............I just can't remember the make,It was 20 years ago.
Sorry that weren't much help was it?
Old January 21st 2003, 05:07
Oliver Knuf's Avatar
We have problems with the distance of the mounting bar. My father and I thought of it, and the only way would be the Schadek, as the auto-stick pump is definitely too small for a Type 4. A steel cover can be used on the Schadek to get a few millimeters less thickness. Could you measure it? We haven't got a 914 here, so it's just a thought of what can fit and what not.
The CB pump you mentioned, is the Schadek, but with a thicker cover. Besides Schadek produces also a fitting version for the Type 4!
Click here to mail me!
