Old January 16th 2003, 23:03
Cyrus2Dope Cyrus2Dope is offline
Pillow-Disc Brakes on an early bus question
I was planning on putting disc brakes on my 66 bus I have dropped spindles up front and bus swing axel in the back (bus boy kit) I was curious what you hadd to do or what you plan on doing to mount your disc brakes? Im getting mine from a 944. Any suggestions? Thanks allot. Peace
Lowered 66' 13 window bus, with a typeIV 2 Litre, next step 944 disks all around + cookie cutters
Old January 17th 2003, 14:08
By the way that early 944 brakes.
-Nick
Old January 17th 2003, 15:12
Pillow's Avatar
Pillow Pillow is offline
For the front you need the adapter bearings from Old Speed to slide the early 944 hub on the stock '66 front spindle. The caliper mounts are also custom from Old Speed. Then you need the modified grease caps from Old Speed. That is about it that is custom. The rest is Porsche parts all the way. Oh and the front rubber brake lines are disc front from a Beetle/Ghia. Easy once you have the parts.
The rear is tougher since you have a Swing-axle. Basically get the early 944 rear brakes complete and then send the hubs to Old Speed to machine them down to fit right, also the caliper mounting plate need drilled to support the larger swing outer bearing. About $100 for the rear mods. The rest is all Porsche parts.
Fairly straight forward but the parts start to add up $$$ after a while
Also see my rambling post on the horror of costs that I have encured over the span of this GL project.
Good Luck,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old January 17th 2003, 15:13
Pillow's Avatar
http://www.germanlook.com/Forums/sho...&threadid=1063
Adrian Pillow
Old January 17th 2003, 22:47
Thanks for your help Pillow, and thanks for that update on my brakes nick
