Old February 2nd 2003, 15:28
Stuart Stuart is offline
Thumbs up rim-fender clearence
Can somebothy tell me if the following setup will mount under my 1303 1979 "vert"with stock fenders:
944T front suspension with 4 pot brembo and vented T disks;
944T rear suspension with early alloy arms, brembo's, vented T disks;
front 7x17 et 55 with 205x40x17 porsche rims;
rear 8,5x17 50 et with 225x40x17 porsche roms.
If stock fenders will not fit what size fenders I shoud buy?
Help is needed here!!!! Greets from Holland.
Old February 2nd 2003, 16:35
I believe the front will work out perfect with no spacers needed, all under the stock fenders.
I am using 17 x 7 et55 with 205/40/17's on the front with stock brakes & I had to use a 10mm spacer. I have done some calculations & it seems like the 944T brake rotors will eliminate the need to the 10mm spacer.
In the rear, I believe you are going to have to run wider fenders.
Those 8.5 x 17" wheels w/ et50 are going to widen your track about 35mm per side on their own. The early alloy trailing arms will widen the rear approximately 25mm per side. And the 944 brakes will also widen the rear about 25mm per side. So this is a total of 85mm wider (about 3 1/3").
I know that under the stock fender you can be as much as 25mm (1") wider per side and still be under them, so if you are 85mm (3 1/3") wider per side, you will need a fender that is at least 60mm (2 1/3") wider to cover them, maybe a little more.
Old February 2nd 2003, 16:36
Superman
Yes, as long as you use the early suspension without ABS. Look in the gallery on my Superbeetle site, there are a few cars that have this set up.
