Old February 6th 2003, 13:03
richiep richiep is offline
911 Headlamps
I'm sure I've read about people fitting 911 Headlamps in to early sloping wing - is this easy to do? Am I imagining it? Any info greatly received.
Old February 6th 2003, 15:07
Superman
All you do is put the 911 lens in the VW light assembly.
Old February 7th 2003, 03:36
Richie's Avatar
Richie Richie is offline
There is nothing difficult about it. Remove the original headlamps and replace them with the 911's.
Don't forget the rubber seal between wing/fender and the headlamp.
Cheers,
Richard
Old February 7th 2003, 05:26
Thanks guys
I never realised it was that easy!
Presumably late 911 headlamps are H4 units - does this mean I'll be able to see at night now if I do this swap?
