Old February 11th 2003, 19:04
BigPhattyVW's Avatar
BigPhattyVW BigPhattyVW is offline
Cam Gear Woes!!
Hello again!!
I was wondering if any VW aftermarket parts manufacturer makes adjustable cam gears, not straight cut, that are in the different sizes that came from the factory? Like sizes from -1, 0, +1 etc... And another question. Just incase they dont make them in different sizes, how much noise does adding straight cut gears add on? I would like a quiet engine but if its not too bad or sounds really cool, this could be another option!!
Clint
Coming Soon!
86mm X 90.5mm German Look Bad *** VW
Hopefully Soon!!
Back home in Port Orchard, and saving for the Bug
Old February 12th 2003, 12:21
Aurumen Aurumen is offline
check out this page
http://www.aircooled.net/new-bin/vie...11200359330148
If the link doesn't work go to www.aircooled.net...then go to engines...then to cams...and look for cam gears page...they have lots of different kinds including an adjustable "stock" type gear.
Nick
Old February 12th 2003, 19:12
lightning bug's Avatar
Most aircooled VW parts manufacturers have adj. gears. They are adjusted by using different washers. Straight cuts sound awesome IMO. They're kinda loud. They wine like a geardrive on a V8. Plus they remove the loads off of the cam bearing.
Julian
'74 Super
