Old February 17th 2003, 19:42
lightning bug's Avatar
11 blade fan parts
Aside from the shroud. What exactly do I need to look for besides the fan itself/alt./and fan housing? Is there any other hardware etc.? THANKS!!
Julian
'74 Super
Old February 20th 2003, 19:00
Martice's Avatar
Martice Martice is offline
Yeah...I would like if anyone could tell us a complete list of parts needed to install a Porsche fan on a flat4.
1. the Porsche fan/alt
2. the ring machined(this is a task)
3. the shroud
4. the band (strap) that fixes the shroud to the case(stand)
5. the pulley(s)
??6.?? is there a must for a stand or you can bolt it to the machined case? what about the breather box in this case?
We are talking about type 4 in my case.
Martin
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old February 20th 2003, 19:03
Martice's Avatar
This is how a t1 kit looks(with stand)
and this is how a t4 looks(without stand I belive)
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old February 21st 2003, 00:41
kdanie kdanie is offline
Martin, the type 4 breather box must be machined so the fan ring can fit in the correct position. The shroud mfg. should supply the dimensions for the machine work with the kit.
ken
Old February 21st 2003, 04:35
Martice's Avatar
Thanks Kdanie, i know the type4 breather box must be machined, forgot to mention.
To be honest here is what I plan to do if I find a 911 fan at a good price: Machine the fan ring, machine the case, build my own shroud from fiberglass.Hope it will work, I can't afford a kit...
I wish to do this mostly because i need the space in the engine compartiment for a plenum for a CIS system.
Martin
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
