Old August 15th 2002, 22:33
bugsoup bugsoup is offline
Hydraulic clutch...
It seems to me that the perfect solution to mounting a Porsche transmission with a push type clutch would be to add a hydraulic clutch. Is this done often? I haven't seen many people do this. What are some reasons that someone wouldn't use a hydraulic clutch?
thanks
Scott
My Blog
Please help me get a minimac
Parts I Need
Old August 16th 2002, 07:14
Alex's Avatar
Alex Alex is offline
The biggest problem is the pedal cluster. Most of them require you to cut the front wall just behind the teh clutch pedal.
the kit I am using is from Saco and I got it thru ISP West.
The cylinder used for the clutch sits in the tunnel and hooks onto the clutch cable hook.
Article to come soon......(a couple of weeks).
Old August 16th 2002, 10:40
Steve Arndt Steve Arndt is offline
pics of Alex's clutch system
http://www.vwispwest.com/specials-ga321000.htm
Steve Arndt
Old August 16th 2002, 22:39
lightning bug's Avatar
That's what I'm using.
Julian
'74 Super
Old August 18th 2002, 04:03
hot66's Avatar
hot66 hot66 is offline
I'm using a hydraulic clutch. I've done this by modifying the bulkhead & stock pedal assy. Car is not running yet so can't comment on how this system works but in theory its all worked out well.
project in progress
Old August 21st 2002, 12:04
greenterbo's Avatar
greenterbo greenterbo is offline
What's involved in doing this mod? Do you have to cut into the tunnel?
Old August 21st 2002, 12:44
Alex's Avatar
Yes you have to cut it.
I will write a detailed article in the next couple of weeks. I will install it soon and I will take lots of pics.
Old August 21st 2002, 18:06
hot66's Avatar
no cutting the tunnel, just modifying the bulkhead
project in progress
Old August 21st 2002, 19:23
Alex's Avatar
For the Saco clutch kit you have to cut the tunnel but not the bulkhead.
Old November 20th 2003, 14:03
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Hey Alex,
How much of a pain was it to install this kit? Do you have any pics?
I've been looking at it and for the life of me, I can't see how it mounts.
Thanks in advance.
Old November 20th 2003, 16:27
Alex's Avatar
I have pics. I will post them on the weekend so stay tuned.
I am also thinking of writing a quick article about the Saco kit. Hmmm.....maybe I should do that on Friday.
Old November 20th 2003, 20:10
yes, we think you should. :lol
Old November 20th 2003, 22:54
DORIGTT's Avatar
Thanks! I look forward to reading the article.
Old November 21st 2003, 17:15
Hi,
I bought the same kit Alex has. Also from ISP West. I will be using it for a 915 trans.
Alex,
Don't forget to include the remark of Shad about the plastic line that should be swapped with a steel one. It is s/where in this forum.
Looking forward to the article as well, since I haven't installed mine yet.
Good luck,
Old November 25th 2003, 09:44
Alex's Avatar
Sorry guys,
this weekend was crazy at work.
I will try to write it this week.
