Old February 20th 2003, 16:45
BigPhattyVW's Avatar
BigPhattyVW BigPhattyVW is offline
Super Diffs, limited slip, and bears oh my!!
Hello again from Playa Del Carmen!!
Could anybody tell me what is a super diff. I kinda know what a limited slip differential does but what is the difference between that and a SUPER differential?
Thanks for the info!!
Clint
Coming Soon!
86mm X 90.5mm German Look Bad *** VW
Hopefully Soon!!
Back home in Port Orchard, and saving for the Bug
Old February 21st 2003, 00:50
kdanie kdanie is offline
A standard VW differential has only 2 spyder gears (low HP/low cost), a super dif uses 4, like most real differentials in the world. A superdif will not increase traction like a limited slip, it only makes the differential stronger.
I think I remember hearing that someone (Berg, maybe?) used shims to make the spyder gears fit tighter and be harder to turn, acting as a poormans limited slip. Probably not very effective though.
ken
Old February 21st 2003, 20:34
Thanks a lot!! I am officially englightend, sorry bad spelling, about the whole differential situation!! Now does anybody know where I can find a limited slip diff for the vw type 1 tranny!!
Thanks!
Clint:silly:
Coming Soon!
Hopefully Soon!!
Old February 22nd 2003, 16:02
kit kit is offline
I think Quaife used to do a torque bias diff for the T1
have a look at
WWW.quaife.com or maybe www.quaife.co.uk
for more info.......beware will not be cheap.
kit
