Old February 20th 2003, 16:57
Question How long will this last ?
Hiya,
I'm going to run a 914 2.0 (95hp) with BAS header, 44 IDF's and Porsche cooling this spring and its all hooked up to a STOCK '72 4 speed trans in my '74 beetle.
I'll be daily driving it through the summer and will be hitting some drivers ed's and autocrosses.
Questions:
How long will this trans last ?
Can I do some drag race starts ?
How about full throttle application after shifting ?
I'm a newbie to trans questions and will upgrade in the future, but will I kill this trans in one summer ?
Thanks for any input !
Old February 20th 2003, 18:24
Michael Ghia's Avatar
How long... how long is a piece of string!
Sandeep,
It's a kinda "how long is a piece of string" question.
I have seen stock Bug gearboxes used in drag racing rails (seriously!) last indefinatley and I've seen £3000 gearboxes blow on the first take off...
It just depends on how you treat it.
If you're running street tyres, you've less chance of breaking it than if you run slicks,
If you setup the rear suspension for drag starts (i.e. quite soft for good weight transfer) then the trans will last longer than if you set if up hard as it will take the shock out of the take off.
There are so many different things to look at.
As for power shifting, the same thing applies, if you slam your foot off the clutch having buried the accel pedal before hand, you're more likely to slip the clutch or shock the transmisison and break something than if you wait to get the clutch up fully and then nail it.
If you're nice to it, it should last! and last.
Rich Olafsson ran a stock 1300 box for 6 months with 240bhp from an Impreza Turbo lump but as you can't control the sudden turbo boost, it died evetually. He's pretty nice to it.
MG
Old February 20th 2003, 19:27
Martice's Avatar
Martice Martice is offline
How about "welded" 2nd and 3rd gear? what is the precise purpose of this operation and what exactlly is the operation?
Martin
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old February 21st 2003, 10:03
Thumbs up
Thanks for the information Mike.
Looks like I will start making plans for a beefed up tranny .. so many options now ..
Old February 21st 2003, 12:34
kdanie kdanie is offline
Martin,
Early transmissions had the drive part of the gear pressed on, newer trans they were already welded from the factory. If I remember correctly only 3rd and 4th need welded. I have some pictures at home I can email you that show the operation. I will try and include the text from the book also.
ken
Old February 21st 2003, 13:32
Martice's Avatar
Thanks Ken!
here is my email: martinchirita@yahoo.com
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old March 8th 2003, 19:05
Wanzer74 Wanzer74 is offline
sandeep, i have been running a stock sb trany and have had no probs what so ever. i do have steet tires on but i did run into a worn out flywheel from a bad starter,chiped the hell out of it. the down fall i do have is on the top end, everyone is in my dust till im runnin at 5 grand and out of forth. thats when i get passed up.(and i have gone way faster than 95, its the darn wind tossing me all around that keeps me from top speed.
2056 porsche 914, zoom zoom!! In a super beetle?
