Old February 27th 2003, 11:54
oldyeler oldyeler is offline
Red face Flywheel shim ,,AGAIN
: I am tired of the run around ,
Jake if you see this please tell me the most common three shim combonations you use when you set up end play i will order by your sugestions That is if you have not already got me some to go with my fle plate and converter Also If you have run ito any more trouble on the converter balance I need to know ,I may have a solution here.
T-4. 2.0 w/t 36 hp upright DTM Going In a 356 Drauz , automatic , 1970 VW Kitkar pictures at Http//home.earthlink.net/~oldyelerbh2
Old February 28th 2003, 04:51
Oliver Knuf's Avatar
Take 2 x 0,24mm, 2 x 0,30mm, 1 x 032mm and 1 x 0,34mm to be on the safe side, even if I'm not Jake!
Click here to mail me!
Old February 28th 2003, 10:27
THANK YOU ! Please tell the rest that didn't hurt
