Old March 1st 2003, 11:45
Cam gears
What are the pros n cons of straight cut vrs. normal gears? Thinking of using st. cut for the engine.
Old March 1st 2003, 13:22
jrinlv jrinlv is offline
correct me if i'm wrong, but straight cut is the way to go if you have any horse power as it eliminates the thrust and is better for the bearings, it is alittle louder though (which is why factory dose not use them)
Old March 2nd 2003, 22:34
lightning bug's Avatar
Exactly. It also requires less HP to drive than the stock. The only real downside as said above is the noise. You'll get a whine similar to a gear drive on a V8. IMO... Definitely worth it.
Julian
'74 Super
Old March 3rd 2003, 01:30
Good point on the extra hp, i really like the noise, it sounds tough,
But i think it's the way to go.
Old March 3rd 2003, 14:01
Smile
Thanks guys for the input. Let there be noise!
