Old March 7th 2003, 16:36
notch62 notch62 is offline
944 rear brakes
I have a set of early 944 rear brakes and I want to up grade from the single piston calipers to 4 pot calipers. Does anyone have an idea if that is possible? The rotors I have are 289mm by 20mm I was told that these are not wide enough to use brembos. Is there a rear rotor that I can use with the early hub and still retain the e brake?
Old March 7th 2003, 17:03
You will need the rear rotor from a 944 turbo (299mm x 24mm) as well as the matching 4 piston brembo caliper.
You will be using factory Porsche parts so you will be able to retain the ebrake assembly.
Hope this helps.
Old March 9th 2003, 11:31
hot66's Avatar
hot66 hot66 is offline
I am using the 20mm thick 944 discs with 968 4 pot brembo's. I will space the calipers out so they sit central over the disc, meaning I will have an extra 2mm gap on each brake pad. I am assuming that as long as I keep the pads & discs in good condition & don't let them wear down excessivly this will be OK.
I know others have done the same as me. IS this OK? Anyone running on the road have any feedback?
Or should I go with the turbo rear discs too? (my front end is using early discs with brembos because the late discs are too big diameter)
project in progress
Old March 9th 2003, 11:34
That will work but you must keep an eye on pad wear, for if the pad gets too thin, there is danger of the pad falling out.
For safety's sake, get the proper rotor to go with the caliper.
Old March 9th 2003, 14:08
Superman
I had a Porsche shop tell me that the Brembos will stress the thin discs too much and crack them, so go easy on them.
Old March 11th 2003, 03:56
hot66's Avatar
out of interest, are the 24mm thick 944 turbo discs the same as the early ones except being thicker & 10mm larger diameter? Are the offsets etc the same?
project in progress
Old March 11th 2003, 16:19
Pillow's Avatar
Pillow Pillow is offline
>For safety's sake, get the proper rotor to go with the caliper.<
Yup. You do not want the pistons falling out of the caliper either.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old March 12th 2003, 04:09
hot66's Avatar
anyone know?
project in progress
Old March 12th 2003, 07:41
Superman
George at 944ecology
George wrote:
Yes, the rear brake calipers will fit on the rear brake carrier.
You will need new rear rotors to fit onto the NA hubs. The hubs use the
NA spindles and NA bearings, so the only parts in the rear you need
to change are the caliper and the rotor.
Good Luck!
Old March 12th 2003, 08:54
Boxster rears use 292mm, 20mm, ventilated rotor, Im using Boxster calipers on my car with 289 x 20 rotors, the Boxster caliper is radial mounted which makes it very easy to adapt.
Steve C
Old March 17th 2003, 04:31
SprintStar's Avatar
SprintStar SprintStar is offline
Steve C
Any idea about the fronts? Easy to adaptor Boxster fronts to the front of a late '03?
Thanks!
Sprint.
Old March 18th 2003, 08:12
Im getting some Boxster S calipers soon. I have said this before so I hope I dont bore everyone. Im going to get some Boxster S rotors, have a hub made to fit it onto a stock spindle without any track increase and mount the rotors on these. Then I will just have a alloyblock style adaptor made to bolt the caliper to the stock beetle stub axle.
Steve C
Old March 18th 2003, 12:49
SprintStar's Avatar
Steve C
Do you have dimensions for the rotors? Thanks!!!
Sprint.
Old March 19th 2003, 05:18
They are 298mm x 24mm.
Steve C
Old March 19th 2003, 05:30
SprintStar's Avatar
Hello Steve,
Have you got a list of all the rotor dimensions for the various Porsche models? Alas, they use different bearings and spindles, right?
By the way, which part of Down Under are ya at?
Sprint.
