Old March 10th 2003, 17:18
GUTTERS GUTTERS is offline
Question what oil filter is the best
Right when i have finished running the engine in, and change the oil what filters are every one running, there is a lot of bad posts on stf about the fram hp1's, so i aint to sure what filter to run on the t4. any help would be good.
Old March 10th 2003, 17:38
lightning bug's Avatar
I'm drawing the conclusion that everyone on the STF doesn't like anything. I use the HP1 and no problems. All of my friends use the same filter. I'm not saying its the best but it works well.
Julian
'74 Super
Old March 10th 2003, 20:15
Massive Type IV's Avatar
I Like Mann or Mahle filters for near stock engines...or I like Wix filters for Hi Po applications..
I dyno tested Fram HP 1 filters and the results were terriable on one of my engines with a need for a high volume flow (Ie, rod mods from hell and open clearances)
Jake Raby
Old March 10th 2003, 20:22
Farmer Farmer is offline
Mann/Mahle or Purolator.
Like Raby says, Fram does not work that well on a T4. Not really sure why.
Old March 10th 2003, 20:40
Good to know. Would you recommend the same brand filter for a T1?
Julian
'74 Super
Old March 11th 2003, 05:44
I for one, have never tried a Purolator on a T1. But in a full flow setup, I havent measured any big difference between the Mann & the HP1. Maybe when we hit 6,5K rpm & up there will be a difference. I never tried that.
However, (just came to mind) I did notice a rather high oil pressure on 1 engine at cold morning startups. (-5 degrees C.) But as soon as the oil got massaged a little bit it vent down to normal pressure. It took like 2 minutes or so. This was Pennzoil 15W/40 oil.
I´m not sure if it was viscosity or restriction in the oil system.
Old March 11th 2003, 14:56
I hope you had a nice couple of days off, Jake. Its nice to have you back here. Interesting that you have also tested filters (what not? LOL)
Gutters,
Ahnendorp (BAS) sells the Kolbenschmidt oil filters. I got the longer filter which is also used on diesel engines. This filter bolts right on and since its longer, has more oil volume in itself. Luckily all BAS headers clear the filter (of course). More oil in your engine is always a good thing, I suppose.
Old March 11th 2003, 15:11
Cool
cheers every one who has replyed. I am going to go with the kobleschmit ones that wally uses. wally do you have the part number for those longer type filters??.
Old March 11th 2003, 15:30
Sure: Kolbenschmidt type nr: 557-OS and Art.No. 50 013 557.
Old March 11th 2003, 16:12
Pillow's Avatar
Pillow Pillow is offline
For the record Purolator makes a HP-1 as well. Can get them at PepBoys.
I like Purolator or Mann/Mahle (if going stock).
No KS units in the states so no idea what they are like
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old March 12th 2003, 23:46
factman factman is offline
i dont think anyone has answered the question of what to use on a type 1 yet. i have a type 1 hi performance. i use HP-1 right now and yes my oil pressure is a little high in the mornings but give it a few minutes and it idles right at 35 until it fully warms up and idles and 10-15psi. so which one should i use that i can get here in the states. i heard kolbensmchidt mentioned but have never seen them in the states so what should i use? thanks. sam
'64 notch 2.5L T4
'70 bug 1776cc
Old March 13th 2003, 22:07
I use K&N. I cut one in 1/2 once. They are definately sturdy. They are expensive, but most of us only change them twice a year. I think they run about $11.00.
Ron
