Old March 13th 2003, 07:15
paul_f's Avatar
paul_f paul_f is offline
944 steel arm - bolts
I have just received my 944 rear arms and brakes (the steel ones) for my splitscreen IRS conversion.
I am currently having my spring plates modified for the 944 arms - do the arms bolt onto the stock spring plates with 4 bolts, 3 short normal style ones and then a different kind in the centre - an eccentric one perhaps (If so what does this one adjust?).
I am also going to use the 944 bushes etc, can anyone tell me what is used to fix this to the trailing arm brackets - is it a long bolt with a nut on the other end, or is like the type 1 style where the clamp has a thread in it which the allen bolt attaches too.
My reason for asking is that I was supposed to be supplied with all the fixings, however I only received 3 bolts that look like the type 1 ones for fixing the and two long bolts with nuts that look more like shock bolts than the bolts to attach the arms to the clamps.
Paul
