Old March 15th 2003, 19:22
beachball6 beachball6 is offline
Question 15x7 35 et fit under stock fenders
will a 35et off set fit ok under stock fenders front and rear with 205's. im brand new to this wheel thing and dont understand offset too much sry for all the questions.
shawn
2332cc 65 looker
68 stock auto stick
i think i can beat your honda maybe...
Old March 15th 2003, 20:39
the 35et represents 35 mm offset from the center of the wheel
so lets say your wheel is 7" wide, the center is at 3.5".
if you add 35mm (about 1.5" approximately) to the 3.5" then you will have about 5" of backspacing.
so that means you will have 5" of your wheel going away from your fender and 2" of wheel going towards your fender lip.
if this is on a beetle you should have no problem using these wheels. I would recommend a 205/50/15 on a 7" rim, maybe 215's in the rear, but I wouldnt go any wider then that.
if this is a ghia or t3 you will probably need a 7" wheel with more backspacing then 5", more like 6" of backspacing (a wheel with a 52et - 55et)
I hope this helps
Old March 16th 2003, 00:29
yea they have 205 60 15 on the wheel just making sure they will fit.
thanx alot
shawn
2332cc 65 looker
68 stock auto stick
Old March 25th 2003, 21:18
SprintStar's Avatar
SprintStar SprintStar is offline
Re: 15x7 35 et fit under stock fenders
shawn
What wheels are these? Porsche never had a 35mm offset. Closest is 36mm. And usually, their 15" x 7" wheels have 23.3mm offset. It's the 6" ones that have 36mm.
Sprint.
Old April 5th 2003, 00:42
samoht samoht is offline
will the 15x7 fit
About 15x7 porsche wheels...
will either offset 23 or 52 fit front and back without rubbing or tearing up the fender?
Matt
Old April 5th 2003, 04:02
SprintStar's Avatar
Will you be using stock brakes or 944 brakes? Stock items 23mm no problems. 944 brakes will widen the rear track. You will need the 52mm offset wheels then.
Sprint.
Old April 5th 2003, 08:26
Thumbs up
I will be converting front and back to 83 994 brakes, rear only hub/brake/caliper conversion (no trailing arms) front converted to 1303 with topline lowering strut (maxx too expensive).
Really, I thought only going to the turbo trailing arm increased width??????
so 944 conversion: 23 offset front, 52 rear??
Old April 6th 2003, 00:55
SprintStar's Avatar
To fit perfectly using STOCK fenders, the only conbination I've come arcoss so far is using 16" Boxster rims. They are 16' x 6" 50mm offset for the fronts and 16" x 7" 40mm offset for the rears and they fill out the fenders perfectly. I can snap a pic of my car if you are interested.
Hehe... And just a shameless plug. If you are interested in a set. I got a spare set you can have. Email me and I can walk you through the whole process.
Sprint.
Old April 8th 2003, 12:21
15 inch audi wheels and the offset is 45 i aparently cant read. im using cb performance brakes in the front and stock drums in the rear. 45 rubs inner fender in the rear so i am getting wheel spacers.
shawn
2332cc 65 looker
68 stock auto stick
Old April 8th 2003, 20:55
SprintStar's Avatar
How wide are the wheels? If they are 6", I don't think they'd rub. 7" maybe.... Coz I'm running 7" rear with offset 40mm.
Old April 9th 2003, 19:57
7 or 7.5 i just ordered a set of 195's and hopfully i shouldnt have as much trouble.
shawn
2332cc 65 looker
68 stock auto stick
Old April 10th 2003, 13:00
SprintStar's Avatar
195s will be a tad too skinny on 7" rims. And on 7.5" rims, it's literally stretching it!
I'd say 205 to be a good choice!
Old April 11th 2003, 19:23
checked 7 inches wide the 195's fit nice they are the avs 100 by yokohomo they r nice
shawn
2332cc 65 looker
68 stock auto stick
Old April 11th 2003, 19:37
SprintStar's Avatar
They will fit, but it's stretching them a bit. When you coner, the contact patch will shift and the bead may seperate from the rim. Try play in your mind what happens to rim when a car takes a corner.
I don't know how to really explain it in words....
Old April 14th 2003, 20:18
understood, but i cant corner hard ne way the tire rubs inner suspension in rear but the tires hook up great i used to b able to chirp 3rd gear with 165 theese i get a tiny spin in 2nd.
shawn
2332cc 65 looker
68 stock auto stick
