Old March 18th 2003, 09:41
mrsmythe mrsmythe is offline
Question rear anti roll bar for IRS'd 944 braked 62 split van
I'm getting my 62 split panel van IRS'd and fitted with 944 rear disks and want to fit a rear anti roll bar so would appreciate some help. From what I've seen on www.performanceghia.com and www.924.org/techsection/10suspension.htm I should be able to fit a 944 anti roll bar with a bit of work.
From looking at the 924.org there seems to be two different ways to attach the antiroll bar, which method is best? From the picutures for one method it seems that I need to get mountings welded onto the torsion bar, but I dont know what needs to be done to the springplates.
Also, I want the handling of my van to be as good as possible without causing a back breaking ride and so am looking to make further improvements. Upfront the kingpins are being replaced with balljoints, 944 brakes and an uprated anti roll bar. The rear is as I've said above getting IRS'd and 944 disks, also a One On One(v.similar to berg) middle mount for the gearbox. What else could be/worth being done? Would a CSP torque bar fit and would it be worth doing? What about a traction bar? Which shocks would be good? The van is going to run on 16" Fuchs with 195/45R16s up front and (probably) 205/55R16s (maybe a 50 profile) out back and is lowered but not ridiculously slammed.
All opinons, advice, etc. appreciated
Ta!
Old March 18th 2003, 14:11
Pillow's Avatar
Pillow Pillow is offline
Good ideas. You are on the same track as me on my '66.
I have a 944 weld on clamp style rear sway bar I hope to get on mine. Not sure how the demension are yet as I have not mocked it up yet.
Are you going to try the 1" sway in the front?
... More to come.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old March 18th 2003, 16:16
hot66's Avatar
hot66 hot66 is offline
i have a 944 rear anti-roll bar complete with brackets to weld on to the bottom of your torsion bars. I'll sell this cheap as its taking up room in my workshop
project in progress
Old March 20th 2003, 08:04
Smile anti roll bar
Pillow, I didnt know sway did a 1" bar for the front, I thought as big as they went was 7/8", I'll have to look into it.
Hot66, what sort of ££ am I looking at for your kit and do you know what I'd need to do about fitting it with regard to things like the springplates?
Was also wondering if a type 1 IRS rear anti roll bar would work?
Old March 20th 2003, 09:28
paul_f's Avatar
paul_f paul_f is offline
If you don't mind me hijacking the roll bar - I will buy it Mrsmythe and try and fit it next week. Haven't put on my spring plates yet so I can still modify them to fit and then let you know?
Can't see a reason why a type1 kit would not work though - the dimensions are all similar...
Paul
Old March 20th 2003, 19:08
Stuart Stuart is offline
Kerscher sells a complete set to bold the sway bar to the floorpan.
Old March 24th 2003, 06:21
roll bar
Paul, go for it mate. Let me know what happens, I'll probably take you up on your offer of popping down to see your bus.
