Old March 18th 2003, 23:31
turbobug73 turbobug73 is offline
turbotach
No interior topic, so here it goes:
I was wondering if porsche ever made a turbo model with a mechanical boost gauge integrated into the tach. The mid-eighties 944T had one, but it gets its signal from the computer, not just a direct vacuum/pressure line. It seems a bit expensive to me to have a 944 computer just to use that gauge. Also, if and early 911T did come so-equipt would the tach work with a 4 cylinder engine?
thanks
Old March 25th 2003, 23:15
yetibone's Avatar
yetibone yetibone is offline
a 911 tach would work, but it would register a slower engine speed than your engine's actual revolutions. A 911 tach needs to see six breaks in the primary circuit for every 720 degrees of crankshaft rotation, where a 944's sees four breaks in 720 degrees. It would probably show 66% of your engine speed.
That's in theory, I've never actually tried.
Yetibone
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old March 26th 2003, 03:35
Yetibone,
Your theory is correct also in practice: Therefore I had my 911 tach reworked by a specialist to work for 4-cyl.
I believe the 80's model 911 turbo's have the tach you want with the pressure gauge build-in.
Old March 26th 2003, 05:17
but no mechanical boost gauge!?
Old March 26th 2003, 05:19
whoops, thx wally
Old March 26th 2003, 08:31
yetibone's Avatar
Wally,
Did you have your tachometer re-worked by a local shop in your area, or did you send it away somewhere for the modification?
When I build my next GL, it will have a 911 style dash, and likely 911 guages. I'd thought of substituting a 911 tach for one out of a 914, but I think the guage bezels are different, and it wouldn't look right with the rest of the 911 guages.
Yetibone
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old March 26th 2003, 15:39
Yetibone,
The tach was reworked by a 'local' bug-only shop here, who in his turn let it do by a specialist close to him. Its not really cheap to my knowledge, but the display is exactly the same as a 914 tach, but for the red-line which is near 6300 rpm. Mine goes to 7000, but some others go to 8000 rpm. At the time, t was the only porsche tach around (already have it for 15 years...).
Old March 26th 2003, 21:06
yetibone's Avatar
Thanks for the info Walter. With that in mind I think I'll use a 914 tach. We just got one on Ebay with the speedometer, the dummy guage on the left, and a pannel already made to fit a 1200/1300/1302.
Yetibone
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
