Old March 25th 2003, 01:39
Cyrus2Dope Cyrus2Dope is offline
Master Cyl for a bus?
I have a 66 bus, early 944 disk all around, what type of master cylinder should I use? I was thinking maybe a master cylinder out of a 944 maybe one out of a turbo if it is even bigger. any opinions?
Lowered 66' 13 window bus, with a typeIV 2 Litre, next step 944 disks all around + cookie cutters
Old March 25th 2003, 04:31
Ig I were you I would fit the 944 part, the weight distribution of the cars can't be that different and the brakes and m/c have been designed to work together
Old March 25th 2003, 23:17
thats a good plan, thanks allot for the info
Old March 26th 2003, 16:46
Pillow's Avatar
Pillow Pillow is offline
I have a 944 MC as well when I go full 944 brakes on my '66 Westi.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old April 1st 2003, 23:44
hey pillow, is there any special stuff i need to use the 944 MC on my bus, mounts or anything??
Old April 2nd 2003, 11:43
Pillow's Avatar
Yes, but just little things.
First you will need the MC mounting adapter that Wolfgang Int sells. Usually used to fit Baywindow MCs to split busses.
Second there is no brake light sensor/switch holes in the 944 MC as it is activiated by a sensor in the brake pedal ***embly. So you will need to "T" a line in the brake lines to fit a sensor bung.
Not difficult, but not the easiest thing either. Right around $50 worth of extra stuff.
Adrian Pillow
Old April 2nd 2003, 19:31
paul_f's Avatar
paul_f paul_f is offline
This needs to be modified slightly to fit, the id of the smaller part of the centre bore needs to be increased in diameter by at least 2.1mm, mine was increase by 2.3mm as the outer surface had not been machined and was not perfectly true.
Having the bigger bore allowed my to modify the rubber boot supplied with the kit and fit it.
Regards
Paul
Old April 3rd 2003, 11:22
Pillow's Avatar
Good point Paul. Something I have not come across yet.
Essentially the Wolfgang adaptor fits Brazilian bay MCs, even the German bay MCs are too big and the adaptor needs opened up a bit.
There is plenty of meat on the adaptor so no big deal.
Adrian Pillow
