Old March 27th 2003, 10:47
jfnelson jfnelson is offline
Stock Tranny
I have a '68 Ghia Vert with a stock tranny that is giving me problems. If I replace it at what point does the stock tranny need to be upgraded acounting for a bigger motor? The reason I ask is I want to upgraded the motor down the line. If I have to upgrade the tranny to do this I would like to do this now instead of later. Thanks
Old March 27th 2003, 11:52
Massive Type IV's Avatar
If you plan on upgrading, the engine and trans need t be built together.....The trans needs to be configured in conjunction with the engines powerband and peak torque.......Not engine size.
Jake Raby
