Old March 29th 2003, 20:26
oval55 oval55 is offline
Rear Trailing Arms
Questions on the install. Maybe I have the wrong arms, but it is not a simple bolt on as I read it is. The spring plates seem to be a challange because they are a completely different bolt pattern, does the plate have to be reworked to attach. These are turbo arms onto a irs pan. Even the front pivot mount is not the same, different size of bushings??? Any help would be appreciated, Darren
Old March 29th 2003, 21:36
Superman
You have to put the VW bushings in the Porsche arm. Also, you have to put the Porsche spring plates on the VW pan. Then it will bolt on.
There is also a place that has to be clearanced for one of the bolt/nut heads on the spring plate.
Old March 30th 2003, 01:26
Thanks, back to the wreckers I go! Is there a easy way to get the bushing out of the beetle arm, the Porsche arm came off very easy.
Old March 30th 2003, 07:57
There is two nut & bolts on the spring plate for the height adjustment, one is an eccentric nut, the other just clamps the set height, its the one nearest the torsion bar. You need to weld the one that clamps on the backside because you cant get a spanner on it, I welded mine on and ground it back a bit so that I needed to take less meat out of the chassis.
Steve C
Old March 31st 2003, 02:27
chigger chigger is offline
I twisted the metal insert out with vise grips then cut the bushing out with a knife. went fast after I figured it out.
Old April 3rd 2003, 20:28
Superman
Since I want to keep the steel IRS arms I haven't looked too much into this conversion. I was wondering what you guys use for the outter mount of the spring plate cover (the 4 bolt plate with the torsion bar bushing).
