Old January 1st 1970, 00:00
samcat's Avatar
samcat samcat is offline
Questions about samcats ride
Old August 17th 2002, 12:59
samcat's Avatar
ENGINE SPEC:
Stock 2-litre crank and rods. Crank balanced with 914 flywheel and clutch. Flywheel lightened.
Rods balanced end to end and with each other.
Rods rebushed.
New Mahle 94mm barrels and pistons, pistons balanced in weight to each other.
Eurorace E-grind cam (280o Duration 435" Lift ) with hydraulic followers.
Bolt together rocker gear.
Schadeck 30mm High capacity oil pump.
Case machined by JMR along with the Porsche fan.
Rebuild heads by LA performance, 48x38 valves, full port & fluff, compression bumped to 9.5:1 (was 8:1 due to forced induction plans)
BAS 911 fan fitting kit.
BAS oil filler tube.
BAS Carb linkage
911 bottom pulley.
GT Mouldings fanshroud.
External oilcooler (12x12), thermostatically controlled flow (80oC), Thermostatically controlled fan (90oC on, 85oC off)
LA Performance J tubes and merge, custom made full flow stainless silencer system after the single triangular flange.
Dellorto DRLA 40's, rebuilt and painted black, sucking through an airbox with large flatpanel K&N filter.
Mallory Unilite optical with vaccum dizzy. 24oMax advance on centrifugal, pair of grey springs, 10o initial. Vac in use (T'd from both carbs).
MSD 6AL ignition system, rev limiter set at 6000rpm.
MSD Blaster 2 coil (with MSD coil bracket).
MOROSO BLue Max ignition leads, tailor made to the exact correct lengths.
Gearbox is a 911/01 5 speed transmission From a 1970 911.
Crankcase scavenging system in use.
CSP oil can with 6 connectors (3 on each side)... Top 2 connect to carbs (suction), middle 2 connect to crankcase breathers, bottom 2 connect to heads (or will do when I get around to it )
*** UPDATED 09/06/2004 as engine was rebuilt a while ago...
Old August 17th 2002, 13:03
samcat's Avatar
1973 1303, Jaguar british racing green (quite dark)
Empi GTV style air scoops on rear sides (over half moons),
Kamei front air-dam (colorcoded. Reduces lift on front axle by 60% at 60mph).
California Vitaloni wing mirrors (colorcoded)
2000 model Jaguar XKR full leather seats
Seat functions:
Forward/backward
seat back tilt forward/back
Headrest up/down
Front of seat up and down
Rear of seat up and down
Lower back lumbar support inflate/deflate
Heating
Clear vision H4 headlights with high wattage ultra white H4 bulbs.
MOMO Millenium leather steering wheel
Electric windows
Central Locking
Full Alarm system + Immobiliser + Total closure
Carbon Joe Carbon Fibre stonechip guards
Carbon Joe Carbon Fibre Running boards
Carbon Joe Carbon Fibre Remmelle style rear wing
Carbon Joe Carbon Fibre Headlamp rims
Carbon Joe Carbon Fibre Dashboard bits
LA Performance Carbon Fibre airdam
Mild tint on all windows, with security film
Heated rear window, also tinted
** UPDATE 09/06/2004 - More carbon bits bought a while ago.
Old August 17th 2002, 13:05
samcat's Avatar
More pictures (some of them have my old wheels in still...)
LINKS GONE For new pictures see below)
Just some info/links I have for my car... Might save someone asking a question.
Cya,
Sam C
Old August 19th 2002, 04:34
Chris Percival's Avatar
Old January 31st 2003, 18:48
Martice's Avatar
Martice Martice is offline
Sam,
Great ride!
Can you help me out here...
Where did you get your Clear vision H4 headlights ? and how much?
Same for the flat Tail lights!?
thanks!
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old February 27th 2003, 10:27
samcat's Avatar
Uploaded some new pictures.
Clearvision headlights and my rear lights are from Machine 7 in the uk (www.machine7.co.uk)
Cya,
Sam C
Old June 9th 2004, 02:23
undecided undecided is offline
SWEEEEEEEEEEET ride, man. sweet ride. :agree:
Old June 9th 2004, 05:33
samcat's Avatar
Pictures from the 9th April 2004.
Cya,
Sam C
Old June 12th 2004, 00:55
TitoRay's Avatar
TitoRay TitoRay is offline
That car is screaming, begging, pleading, clawing at its owner for 17's.
1974 1303
Old June 12th 2004, 12:51
samcat's Avatar
Lol,
Got a project car I am doing up to sell at the moment, The profit from which is earmarked for 17's, rear disk brakes and some engine work
Arospeed Riot's:
CYa,.
Sam C
Old June 12th 2004, 14:56
TitoRay's Avatar
...and it only gets better.
Once again, great car!! :agree:
1974 1303
Old June 15th 2004, 02:36
samcat's Avatar
Previous front bumper was damaged in one corner (From my crash a few years back) so I had decided to replace it... Did it at the weekend.
Carbon airdam from LA Performance.
Blacked out indicators from CSP.
Foglights from local boy racer shop, fitted with 130watt bulbs.
Airdam is a nicer fit than the kamei one, and gains me about a half inch of ground clearence (every little helps!)
Did require me to work out my own mounting, not a problem... Used 4 8mm bolts with repair washers (to spread the load).
The bottom sides of the airdam are tied back into the wings with threaded rod, prevents any flexing at speed.
Painted the bumper in the back garden with 2 pack
Cya,
Sam C
PS. anyone wanna buy a kamei airdam?
Old June 15th 2004, 17:06
super vw super vw is offline
Hey Samcat, im interested in the airdam... PM me if you could
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
