Old April 7th 2003, 21:58
Cyrus2Dope Cyrus2Dope is offline
Powder Coating fan shroud, wasnt sure where else to put topic
If i should have posted this in another forum then I apologize, there is no painting section, but it does have to do with the engine so i figured this would work. I got a 36hp shroud for my type IV engine from Aircooled.net i ended ordering one of the "Zinc Coated" shrouds with hopes of powder coating it. Does any one know if I can do that to somthing that is Zinc Coated or would i have to beed blast it first. Would I be better off painting it with acrylic paint or the same crap im going to use on my car? Thanks Allot
Lowered 66' 13 window bus, with a typeIV 2 Litre, next step 944 disks all around + cookie cutters
Old April 7th 2003, 23:38
55rag 55rag is offline
If you get it powder coated the shop will bead blast it anyway, It won't be a problem. Also painting with the same paint as your car wouldn't be a problem although it should be primered first.
Old April 7th 2003, 23:41
i have all the stuff it takes to powder coat the shroud i just dont have a bead blaster yet
