Old April 8th 2003, 16:17
sparks sparks is offline
Newbie 928 Brake question
My co-worker has a 1983 928s parts car. Reading thru the posts here I only saw 944's mentioned. Does that mean I'm out of luck for the brakes from the 928s?
sparks
Old April 9th 2003, 15:36
Superman
From what I know, and get a second opinion, the calipers are the same along with the rear discs as the 944. The reason the 944 is mentioned is because that model (924/944) was based on the VW Super Beetle suspension thus the parts interchange easy.
Old May 8th 2003, 07:24
typ4boy's Avatar
typ4boy typ4boy is offline
928 front calipers are radial mount currently doing a kit for a customers 1303 kit will be out very shortly regards Lee L.A.P
Old May 12th 2003, 21:02
Superman
The 928S4/928GTS front calipers are radial mount but the early 928, single and four piston calipers, are axial mount (same as the early 944).
