Old April 10th 2003, 17:15
GUTTERS GUTTERS is offline
polishing the engine case.
right let me run this past you lot. My mate said today at work why dont you polish your type 4 case inside and out. i said i may do the out side and remove the casting marks and roughness. what if any thing will polishing the inside the case do????.:silly:
Old April 10th 2003, 23:18
Shadowbug's Avatar
I polished the finns on the bottom side, looks nice
Old April 11th 2003, 10:36
kdanie kdanie is offline
Polishing the case inside is pretty useless. You should smooth all sharp edges and remove the casting flash inside to aid in oil drainback. You would be surprised at the amount of casting flash a type 4 has inside the case. Some is just waiting to break off and get into your oil system....
ken
