Old April 14th 2003, 10:54
Jim Andritsakos's Avatar
wbx torquing cylinderheads !
As I will try to torque a pair of AMC heads in a wbx they push the gasket very vey tight as if I try to torque the studs with 30+ kg !!!
I try another heads and is okay...Sooo with a good resufacing the heads where the seal used to be and in the cylinders area (some amount of machining) they will be okay to reuse ???
Jim Andritsakos
74 1303 GL (project)
89 T3 Syncro panel
