Old April 15th 2003, 20:03
Rob's Avatar
Rob Rob is offline
Wohoo !! Drove my bug today
Yeah !
Just drove my bug around a bit, I'm stoked !!!
I was able to cure (most of) the hesitation by setting the timing and fiddling with the carb settings. I need to readjust still, but at least she runs.
Steering is super heavy, the quick steering plate in combination with the 205 tires, lowered front beam and caster shims make for some heavy steering !! And that's with the stock steering wheel....
It also feels a bit 'nervous', but I think that's also because I am moving around quite a bit on that worn-out seat.
Man, this feels good, the bug looks like crap, but I don't care.
If the weather keeps up I might even drive it to work !!
Sorry about the reambling, just needed to get it out of my system :silly: :silly:
Rob.
Old April 15th 2003, 21:22
Alex's Avatar
Alex Alex is offline
Rob,
good for you. That should give you enough spirit to finsih the project.....I hope.
Btw...how are the Konis in the front?
Old April 15th 2003, 21:30
Rob's Avatar
Rob Rob is offline
Thanks Alex.
Haven't even put the Konis on :tisktisk:
Hopefully I can do that this friday so I can test them when I drive to the meet next week :haveadrin
Although I won't have the nerve to drive it on the QEW,
I'm taking Hwy 5 :hehehe:
Rob.
Old April 16th 2003, 09:37
Thumbs up
Cool !
I hope I'm not going to be the only one driving my bug to the meeting !
Glad you got it running.
Old April 17th 2003, 01:42
petevw's Avatar
petevw petevw is offline
hmmmm.......
2 weekends, this one being longer than the other:
install shroud, TB's, linkage, exhaust, electronics,
break in, and tune.....
probably won't do the brake/tire swap now, i'll do it in May.
oh no...i see many long days/nights ahead.
i will try to bring mine, and make it 3!
later,
pete
'72 super
'65 bus
'52 split
Old April 23rd 2003, 11:33
petevw's Avatar
UPDATE:
need to install TB's, fuel rail, injectors, spark plug cables.
break-in and tune.
almost there now, so close.
later,
pete
'72 super
'65 bus
'52 split
