Old April 21st 2003, 17:19
Stuart Stuart is offline
spare tyre
Can somebody tell me what type of porsche spare tyre fits my 944T suspension(4-pot brembo's). Do they fitt the in the trunk of my 1303 super.
Old April 29th 2003, 16:32
Question Spare tire ?
I thought I would make this thread a little more generic.
What are you guys running the 5x130mm stud pattern using for a spare tire ?
Please let me know where you are storing the spare and what mods you may have done to store it.
I know I can only fit a 15x4.5 spare in my standard's spare tirewell.
Old April 30th 2003, 09:07
Im using a 15 inch Porsche space saver. The only problem is were do I fit the flat once I change it.
Steve C
Old April 30th 2003, 09:55
Question
I never thought of that !
Where do you put an 18x10 with 265/35 when you have to change it ?!?
Old April 30th 2003, 11:12
Im using a 15" Porsche Space Saver.
Im sure you can put your wheel in the back seat area once you change it
Old April 30th 2003, 12:31
Hello-
I went the el-cheapo route. I got an old 5-lug 356 rim (4.5x15) for $25 and put a 165 tire on it for $0. You could even put an original bias-ply tire on it and make it fit in a Ghia spare tire well (even 165 is too big for a Ghia's space).
Take care,
Shad Laws
Old April 30th 2003, 13:37
What size spare do you need if you are running 993TT brakes?
Old April 30th 2003, 14:51
I had saved a 4,5x15 Fuchs to use as a spare, but no model Fuchs (not even 16") fits my Brembo brakes on the front... So I left the spare out all together! Saves weigth too. After that I decide to put the battery in the front on the floor, so now a spare doesn't fit anymore anyway.
My cell phone is much lighter than a spare if I would ever got a flat tire (has never happened tho).
Old May 2nd 2003, 18:12
MattKab's Avatar
MattKab MattKab is offline
I've not got a part number but this is what we need up to when the unthinkable happens:
Old May 2nd 2003, 18:22
MattKab's Avatar
'Looks like a pink pug 1.9gti wheel to me!
Standard 944T spare' is it not? But what year?
Can anyone confirm this will indeed fit in the 'well of a Super?
I may have found one. Please?
Matt
(That is a pic from here awhile back)
Old May 3rd 2003, 00:34
Superman
My spare tire well is filled with a radiator :silly:
Old May 3rd 2003, 00:36
Superman
Measure the diameter of the tire well, then you'll have the maximum size fitment and can compare spares.
Old February 11th 2005, 01:05
GRMNLK's Avatar
GRMNLK GRMNLK is offline
I have a question about a spare wheel, but I don't want to have to start a new thread...
I have CB dropped king/link discs up front and was wondering if anyone knows if a 5.5 x 15 space saver rim with a 165 from an old 911 will spin with out interfering with the caliper? My first thought is yes because they are vw parts and they aren't "big reds".
Old February 11th 2005, 06:50
My solution is a porsche 996 spare tyre. It's a inflatable type but fully inflated it will fit the sparetyre well very nice!!!!! Forgot to say it's a 17 inch rim.
Old February 13th 2005, 10:01
justdubbin's Avatar
Stuart, have you got the part number please :agree:
Rob.
