Old April 23rd 2003, 23:36
Cyrus2Dope Cyrus2Dope is offline
Type IV oil Filler
Does any one know where to get the upper portion to a type IV oil filler, not the long metal piece that comes out of the block itself, but i am looking for the extension that comes off of that, that has the cap itself on it, from the look of pictures it apears to be rubber or plastic and attached to the metal tube, any one know where i can buy one?? thanks
Lowered 66' 13 window bus, with a typeIV 2 Litre, next step 944 disks all around + cookie cutters
Old April 26th 2003, 14:07
papun5880pr
IT IS PLASTIC AND YOU ARE RIGHT!!!!
IT GOES ON THE METAL PORTION ON THE ENGINE. LET ME GET SOME PICTURES AND MEASURENETS AND YOU CAN GO FRON THERE TO BUILD ONE. EASY STUFF. IF NOT YOU MIGHT CHEKGERMANPART AND FILL THE REQUEST FOR IT. I GOT MY SLIDING DOOR MECANISM AND MY SIGNAL LIGHTS SWITCH FROM THEM. IF YOU CAN, LET ME KNOW TO GIVE YOU THE LINK. ALSO CHECK www.samda.com on classifieds for parts.Good luck,\. If i see one, i'll pick it up for youapun
Old April 26th 2003, 14:09
Danny, that is www.thesamba.com/
Old April 27th 2003, 10:57
Hey thanks allot danny, you wouldnt happen to know the propper name for that tube and cap assembly would you? or is there even one?
